- Reaction score
- 0
Discuss How to attach ceiling light clear wires in the UK Electrical Forum area at ElectriciansForums.net
So do I connect the wire and the bulb fitting to the meter? How do I know which is N, L or earth? Do they have different Ohm readings (sorry I’m a bit clueless!) thanksyou set it on ohms. each wire will show a reading close to zero when you have both ends of the same wire connected to the meter.
Thank you so much!you should get continuity ( almost zero ohms ) between L and centre contact, N and outer thread, E and metal casing. in that order. 1 probe on end of wire. other on appropriate part. if you haven'tgot amultimeter, you can knock something up witha PP3 battery and a car tail lamp.
I will buy a multimeter/continuity tester (are they the same). To test the earth, do I attach one end to wire and other end to ground (fridge, radiator)?As you have bought this second hand, make sure you definitely have good continuity between the earth wire and any metal parts (should be reading under 1ohm on the multimeter). Ideally you would carry out an earth bond test using a different piece of test equipment.
Have you got suitable terminals to join this to your lighting circuit?
Reply to How to attach ceiling light clear wires in the UK Electrical Forum area at ElectriciansForums.net
