- Reaction score
- 0
Discuss How to attach ceiling light clear wires in the UK Electrical Forum area at ElectriciansForums.net
Continuity tester to confirm the SES lamp holder connections.
I doubt the ES lampholders are polarity biased. Assuming one is earth that is the one you need to find. You are going to need a continuity tester to find it.
I was told to always ensure the live was the centre pin in ES light fittings, to avoid electrocution when removing the bulbs.
Yes that is true but with multiple lamp holder fittings and even a majority of cheap lights from over seas i always check, you will be surprised how many are not
On many modern ES lampholders the outer contact disconnects before the outer part of the lamp is accessible, so in practice it is not essential to make the centre contact the line. But IMO it is best practice and ensures compliance to do so.I was told to always ensure the live was the centre pin in ES light fittings, to avoid electrocution when removing the bulbs.
ES lampholders manufactured to en60238 which is the required standard are not polarity biased. Both poles are at the bottom of the holder and disconnect when the lamp is unscrewed, improved construction prevents the outer metal screw cap being exposed until the contacts are no longer touching the lamp.I was told to always ensure the live was the centre pin in ES light fittings, to avoid electrocution when removing the bulbs.
Ensures compliance with what.On many modern ES lampholders the outer contact disconnects before the outer part of the lamp is accessible, so in practice it is not essential to make the centre contact the line. But IMO it is best practice and ensures compliance to do so.
Definitely no colours running through the wires. Thanks though!Often (but not always) find if you look closely at the clear wire there is a fine green yellow colour running through one - this is the earth. Also a fine brown through another, which is the L, and a fine blue colour through another, alas this is the N.
It's not always the case of course, and it can be tricky to see even in good light.
I bought it second hand from gumtree.Is the fitting new? It looks like one of those wires has preiviously been soldered to something. It may be the earth connection and may need to be soldered to the metalwork.
So basically a continuity test won’t tell which wires are L, N, earth?Sounds like you are a bit stuck and we cannot guess what wire does what. Best advice is to use the services of an electrician.
If you have a continuity tester and know how to use it then yes it will.So basically a continuity test won’t tell which wires are L, N, earth?
I’m borrowing one tmw but no, I’m not sure how to use it. ThanksIf you have a continuity tester and know how to use it then yes it will.
Or some old headphones/earbuds ? Lots of ways to do it...You could always make your own continuity tester with a torch and some wire...
I don’t know how to test if wires are L, N or earth using this. Can someone please explain, thanks!You could always make your own continuity tester with a torch and some wire...
[automerge]1570484058[/automerge]
you set it on ohms. each wire will show a reading close to zero when you have both ends of the same wire connected to the meter.I’m borrowing one tmw but no, I’m not sure how to use it. Thanks
So do I connect the wire and the bulb fitting to the meter? How do I know which is N, L or earth? Do they have different Ohm readings (sorry I’m a bit clueless!) thanksyou set it on ohms. each wire will show a reading close to zero when you have both ends of the same wire connected to the meter.
Thank you so much!you should get continuity ( almost zero ohms ) between L and centre contact, N and outer thread, E and metal casing. in that order. 1 probe on end of wire. other on appropriate part. if you haven'tgot amultimeter, you can knock something up witha PP3 battery and a car tail lamp.
I will buy a multimeter/continuity tester (are they the same). To test the earth, do I attach one end to wire and other end to ground (fridge, radiator)?As you have bought this second hand, make sure you definitely have good continuity between the earth wire and any metal parts (should be reading under 1ohm on the multimeter). Ideally you would carry out an earth bond test using a different piece of test equipment.
Have you got suitable terminals to join this to your lighting circuit?
Reply to How to attach ceiling light clear wires in the UK Electrical Forum area at ElectriciansForums.net
