Discuss Good Morning Thread - Come say good morning, tell us what you've got on today. :) in the The Electrical Exchange area at ElectriciansForums.net
I had been given an old Philips 60Mhz dual trace 'scope last week. It had been standing around for a few years so I decided to power it up and see if it worked. I've just plugged it and and up came the screen. Apart from two of the controls being a bit 'scratcy' all seemed ok until that ppfffzzzzzz sound and the smell of electrolitic capacitors letting out smoke. I've had the cover off and things don't look too bad. I've just downloaded the service manual so it loks like after a bit of trawling through it I'll be on the Farnell web site ordering a selection of caps.
Sounds good. I've got a nice Telequipment 75MHz dual beam scope which I've had since I was about 15 I think. Could replace it with a modern one, but you cant beat a proper analogue scope with a nice bright green trace!
what about 1?
Good morning everyone, I have 1 job today hanging and wiring LED security lights on a home at all 4 corners. The bad part is it’s 19 degrees outside with the wind blowing about 8 miles per hour and I get to use my extension ladder to climb up around 20 feet to be able to mount the boxes and lights. I then have to go in the attic to pull a new circuit to the 4 lights from the panel using a 15 amp single pole breaker. Yippee
The original poster has taken the video down now, i think because some comments suggested it was an insurance job and it turned into a slagging match.
I remember when you posted about the sale of the park and the problems your FIL was having with the new owners (chancers) claiming all sorts of things, so the above may not be so far removed from the truth.
Well they had been treating the caravan owners badly... telling them to upgrade when there’s nothing wrong with units etc. Industry normal practice, but not something we did.
I think we can rule out any electrical fault, but the 200 solar panels on the roof will be useless now
Found another source of photographs.
Gas cylinders are pretty close!
I'd like to go to work by boat!
I used to use the Thames passenger ferry between Greenwich and the City whilst it was in operation, did not last long though, no idea if the Woolwich ferry still operates, been out of London for a few years now.
@littlespark gas cylinders going up would have been interesting, but dangerous for the fire fighters and quite a big bang I would have thought.
Reply to Good Morning Thread - Come say good morning, tell us what you've got on today. :) in the The Electrical Exchange area at ElectriciansForums.net
What's the most badly designed accessory you've had to install? I present my nomination, the ML Accessories/Knightsbridge RWL5 wall-mounted LED...
Merry Christmas from ElectriciansForums.net What a weird year we’ve had! We will need to keep our wits about us during these next couple of...
5K
Just venting a little.... At 2:45pm I'd finished another job early. So I thought I'd have an initial look around a really small 2 bed bungalow...
Electrical News | Electricians News - News and Articles for the Electrical Industry News and Articles for the Electrical Industry - Electrical...
6K
I'm hoping someone out there has come across this problem. Just had -8 days ago- a 6k solar panel system plus 4.8k battery pack installed. When...
9K
