Currently reading:
UK First time DiY post - trying to find a 2 pin connector for some lights
Discuss First time DiY post - trying to find a 2 pin connector for some lights in the UK Electrical Forum area at ElectriciansForums.net
David_C
Hello, 1st time post from an amateur. I have some old Habitat decorative lights that are powered by a transformer. There seems to be a break in the wiring as the lights go off when the wire is moved around so I was going to shorten the wire. The problem is that I can't find a replacement connector - it's a 2 pin connector - pictures attached. any ideas on where I could get a replacement? Many thanks.
Reply to First time DiY post - trying to find a 2 pin connector for some lights in the UK Electrical Forum area at ElectriciansForums.net
