Discuss First time DiY post - trying to find a 2 pin connector for some lights in the UK Electrical Forum area at ElectriciansForums.net
David_C
Hello, 1st time post from an amateur. I have some old Habitat decorative lights that are powered by a transformer. There seems to be a break in the wiring as the lights go off when the wire is moved around so I was going to shorten the wire. The problem is that I can't find a replacement connector - it's a 2 pin connector - pictures attached. any ideas on where I could get a replacement? Many thanks.
Yes, have a Google for 2 pin DIN type speaker plugs. You can get solder type or screw terminal type.
They are very cheap. You'll definitely get them on ebay.
Oh and welcome to the forum!
Reply to First time DiY post - trying to find a 2 pin connector for some lights in the UK Electrical Forum area at ElectriciansForums.net
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hi all, Replaced a ceiling light yesterday (I'm a novice but confident with basic electrical work). All was well and working, so I turned off...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
Hi everyone, I really hope someone will be able to help. So last night I tried to change 2 ceiling rose / pendant lights at my mother in laws...
