Currently reading:
UK Repairing Christmas light projector
Discuss Repairing Christmas light projector in the UK Electrical Forum area at ElectriciansForums.net
TheJay
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they used to. Looks like a couple of wires have come loose between the board and the motor wires.
I'm not sure which points they need to be soldered back on to. If I try the two empty contacts on the board, there isn't any movement in the motor. Other combinations cause one more more of the LEDs to lose power, so not sure what to do/what I am missing.
Could someone please help?
Many thanks.
Which ones have you tried?
I would expect these two…..
As they seem to be the only other ones that look “used” but that might be from where you have tried already.
Do you have a multimeter that you can use to measure voltage?
Thanks for your reply, I do have a multimeter. What do I need to do?
The contacts you have circled are the ones I tried. I think the red wire may have been connected to the bottom contact as the end of that wire was missing and there was a bit within the solder. The problem was when I tried connecting the white wire to the other one, it stopped some of the LEDs working.
Did you try it the other way around, or was there red remains in the solder?
Use the two prongs of the multimeter to measure between the two connections on the board. When the motor is supposed to run, there will be a voltage value present, and zero when not.
Set the multimeter one stage higher than the supply voltage of the device, and have it on DC Volts.
View attachment 115134View attachment 115135View attachment 115136
Many thanks.
Put the motor directly onto the batteries / power supply first to ensure that it's working.
See post #5
If the motor is jammed it will likely take more current which could cause the voltage across it to fall.
If it won't run on a 3V battery it's probably at fault. If you can get into the whole assembly you might stand a chance of finding what's wrong. It could be the reduction gears or the optical element they turn is stuck, or the motor itself, but in my limited experience the motor bit tends to be more reliable than the plastic/nylon gear trains they drive!
PS: Are you running the whole light projector off its original power supply?
Thanks for your reply. I removed the motor from the gear housing and it spins freely when I turn it, but when I use a 3v cell button battery it does nothing.
It looks like the motor from a CD/DVD but in my experience those don't usually have cables coming out of them, they connect using contacts on the base that aren't available on this one.
How would I track down the right one? Does it have a specific name? Do they come as standard with 7 holes in the top?
I was running the whole projector off it's original power supply.
Since the motor, when connected to the pcb, causes the led to dim, and the voltage on the terminals it connects to drops from 3.2V to 0.6V, the motor seems to have a low resistance (but not work!)
Another test could be to put the multimeter on a low dc volts range, spin the motor and see if any voltage is generated by it!
If it doesn't run on a battery looks like it'd died. Have you tried spinning it while on the battery?
There must be zillions of motors out there, finding a replacement could be a challenge.
If you are able to take the pinion off the motor shaft to put on the new motor, you will need the same shaft diameter and length on the new motor, and preferably at least one fixing hole to line up!
DC 1.5V 3V 5V 6V 6600RPM Micro RF-300C Motor Small Round?​
That 300C reference looks useful.
Prompted by your post I had a quick look and they do look similar, eg:
If you have a pair of vernier callipers you could check the measurements of yours against the drawing dimensions in the link above.
They do look alike!
Good luck!
Thanks for your replies. I have tried testing on low volts and ohms and not getting a reading when spinning. On ohms it's reporting OL.
I've ordered two dc motors, just noticed they aren't expected to arrive until 5th June though...
See post #5
I've got a couple of things to fix where the motor seems to be the problem.
I don't understand what could be broken in this assembly? Does the circular magnet wear down over time and need replacement? If so, where can I get one?
Magnet shouldn't be a problem.
The common failures are a break in the armature coil, or the 'brush' mechanism worn or not making contact. It looks like one of the contacts is bent up (ringed), shouldn't that contact spring be straight? Or has a bit broken off!
Those two contacts should press lightly (but not too lightly!) on each side of the commutator to provide current to the coils.
Use the ohmmeter to set it up.
Well that's the problem.
One spring 'brush' contact on the Christmas light motor seems to have got bent, with one of the leaves pulled away in the wrong direction from the others (outlined red below). If that bent back piece was touching the same commutator segment as the other brush, it would explain why the motor didn't run, but had resistance.
Maybe the black is the remains of what were small carbon brush contacts, or it's some sort of grease?
I don't think there is much point in trying to restore it or fabricate a replacement given the motors are so cheap.
If there's enough of the springs left, you might get the motor to run by cleaning them up and bending them together, but I don't think it will last for more than a few minutes, or perhaps hours if you're lucky!
Thanks for your reply, just as well I ordered some new ones base on what you said! Is there a way to determine the RPM and other identifying information on one of these from the internals when it's broken?
Different RPMs are going to change the speed of the projector lights, or in the case of a Furby, perhaps stop it functioning properly.
I believe the speed will largely depend on the voltage you run it at, and the load provided by the friction of what it's driving.
There is no specific rpm as such (eg servo control). Instructions might give a max speed, but you just need to supply a voltage that gives the correct speed of operation.
It's all going well, the motor works and the parts fit. I tried cleaning the round disc containing images of santa, snowman, holly and bells but now two of the images have been destroyed. Does anyone now how they are made/where to get supplies from?
It says "H46-005" and something in Chinese? "Just"?
The images are 5mm each, I think the gobo wheels are a lot bigger.
Disc size is 46mm, central hole is 7mm and the mounting holes are 3mm. The distance from the edge of the internal hole to the centre of the images is 11mm.
I have ordered some printable acetate sheets for my laser printer, I can try and recreate them or perhaps add my own designs. I'd prefer a ready made option though, perhaps someone else has experience with this?
Reply to Repairing Christmas light projector in the UK Electrical Forum area at ElectriciansForums.net
