Discuss Earth bonding to Water in the UK Electrical Forum area at ElectriciansForums.net
Hemant007
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes.
There is already earth boding near Gas meter and the gas copper pipe enters the house.
Water main supply is via blue plastic pipe (MDPE) which then connects to plastic pipes and also some copper pipes (pipes under boiler are copper pipes, central heating pipes (flow and return pipes) are combination - somewhere copper somewhere plastic).
The consumer unit is metal box with RCD protection, the are 2x RCDs 30mAh, each with 5 MCBs.
Do I need water pipes earthen - the copper pipes under boiler and the some copper pipe sections under the kitchen sink with stopcock?
Thank you.
Thank you for quick response, with my limited knowledge my understanding is also same as the main water pipe is not metal, I am not sure why an electrician will suggest to get the earth bonding to water done,
It makes me think that just adding some work to generate some income ! Sorry not sure, the electrician who suggested to do the earth bonding to water pipe as he can see some copper pipes under the boiler and under the sink.
The whole bonding thing is for extraneous metalwork. Ie, meaning outside the building.
If it’s a plastic pipe supplying water, then it is not metalwork… whereas a copper gas pipe is, and does need bonded.
An electrician suggested that - the copper pipes under boiler and the some copper pipe sections under the kitchen sink with stopcock need to be bonded.
If copper pipe goes under the wood flooring to reach radiators (not under earth ground) does that needs to be earth bonded ?
Thank you.
Out of interest only, why did you suddenly decide you needed to know if bonding was required to the plastic piping? just intrigued
no he did not test any pipe work, he could see some copper pipe, he could see copper pipe under boiler, I mentioned the main water supply is via blue plastic pipe, but he said the metal pipe inside the property needs to be bonded, so I feel he may just be making up some work to make money !
The only really way to know is to test it.
Reply to Earth bonding to Water in the UK Electrical Forum area at ElectriciansForums.net
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Hello, Carrying out remedial work on a commercial site and I've come across a metal out building that has a water supply to it. The water pipe...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Electrician has done rewire, plumber with not much space has some central heating and hot water pipes touching in some places. See images...
