- Reaction score
- 17,246
Just to be clear… I am going to do the correct thing here and pay for the correct parts…. I just wanted to start the discussion.
My particular situation on a job, all I’m doing is adding to an rfc. Moving a couple of sockets off the skirting board, adding a fcu up to a switch, then wall lights.
The present board is a Memera 2000. Mainswitch and circuit breakers. No rcd on any circuit. Have advised and priced for a replacement full RCBO board as a future job….
But in the meantime, I’ve got to add rcd protection to the circuit I’m working on.
Why are Eaton (MEM) rcbo’s so much more expensive than anyone else?
Other manufactures will physically fit the space and busbar shape… whether Hager, proteus, whatever… I haven’t tried any because I am fitting the Eaton one…. But if it can be done without cutting the front cover to make it fit, or it creating a IP issue…. surely fitting any make of rcbo is better than none at all?
