Currently reading:
Must have electricians toys
Discuss Must have electricians toys in the Electricians' Talk area at ElectriciansForums.net
R
RichardMoore
I've recently had a spending spree on new tools and was wonder what other peoples must have top 3 toys were? The ones I've just bought are
1. Armeg box cutter
2.chalk line
3.Meggar trailing lead
Am just currently wondering about what to by next.
Cheers
decent MFT.
power quality analyser.
several decent multimeters (industrial)
stuff to make the inspector & tester`s life easier
the usual: VDE drivers, snips, pliers etc
mini hacksaw (SWAs)
selection of hammers & chisels
chalk lines, holesaws & levels
seesnake
110V & battery drills
core drill & cores
angle drill
jigsaw ( a good one)...not power devil...or some other crud like that
the list goes on......
Fluke 1653
Makita 18v Li-ion black and white set
Laser Level
110v Chop saw
Sey square
Ratchet cutters
Hydrolic Crimpers
Flat bar and crowbar!
thats at a what has made my life a lot easier over time!
decent MFT.
mini hacksaw (SWAs)
seesnake
core drill & cores
angle drill
What the deuce is a seesnake!?
1. Armeg box cutter
2.chalk line
Cheers
Don't need a box cutter. Measure, mark, stitching drill, then chisel drill out.
Cordless grinder with 1mm cutting disks.
Cobra reel
Super rods
Socket set
Cordless impact driver
Cross line laser
Spot laser
Cone cutter
All my tools are a must have toy!!! Although, I would like to get hold of a pyro cutting tool!! Not that I have much need for it but its just nice to have one.lol
What's wrong with a junior hacksaw......unless you mean a joistripper.
What are these inspection cameras are they any good. I can't see where I would use one :-s
i thought exactly the same about my multimaster and my ipad
Just ordered a ryobi inspection camera for £65, after using my mates last week for finding lost downlight cables after drilling the holes out, used to use a mirror on a stick and a bit of bent 2.5 t&e lol
They come with hooks and all sorts for finding lost cables, gonna be one of them tools you dont know how you got on without, i think for me, if only for downlighters as i probably put in hundreds in a year
i assumed they would be more expensive, but for that money i gotta have one
also just upgraded to rhino roof ladder clamps rather than the standard screw up/down ones, sooooo much easier! Well worth a look! :)
Is that the only time you use camera? Ive looked a few times when im feeling flush for possible future tool.
I never struggle with downlights. I can get my arm in a 70mm hole right upto my elbow.
I havent got it yet its on order,
i meant even if i only use it for downlighters it would be worth it, as unfortunately i can only get my hand into the holes for adjustable spots :( which i rarely use in comparison to fixed
im sure i will find lots more uses for it once its on the van, eicrs for one maybe? And other lost cables and under floor work?
Reply to Must have electricians toys in the Electricians' Talk area at ElectriciansForums.net
