Search the forum,
Discuss 63 amp barduct tap off boxes in the Australia area at ElectriciansForums.net
M
MELATPSM
Hi
Can anyone help me locate any 63amp BARDUCT MK1 Tap Off Boxes we have tried the Seimens replacement but these are of no use.
Either New or Used i would be very grateful
Think i may have a couple 125A in the stores which i know you can still get from siemens but not sure if they are MK1 or 2. do you have a picture ? as from what you say mine may be MK2 then.
Whoops, just seen the date :mad2:
:rofl: You been sampling the Christmas cheer a bit early ?:26::tounge_smile:
thanks mate, thought that. just found the site so i thought i would sign up and have a go. got to find out now how to sell stuff on here. looks a valuable site, just left a reply to cables run in a loft (another old post!! :))))
It's ok i've just been answering the question on that 1 lol, somebody has resurrected it for some reason.
If you've got some kit to sell off then there's a section towards the bottom of the front page.
By the way welcome to the Nuthouse.:D
Can you supply any Barduct tap off boxes?
Reply to 63 amp barduct tap off boxes in the Australia area at ElectriciansForums.net
Hi, if anyone can help I’m looking for some Simplex GE. Tap off boxes, 63, 100, and 200a TP&N. Can be new or used but must be suitable for use.
SIEMENS - BVP:BT1133 , TPN FUSIBLE TAPPING BOX, BARDUCT BL RANGE, TAP OFF BOX, AUTO SHUTTERS, 3 PHASE + N Perfect working condition, had only...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Looking to use this brooks Compton motor as a replacement in an electric cement mixer. can anyone tell me if it is designed to operate off a...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
