- Reaction score
- 17,159
From Screwfix I think I got a 5Ah combi with 2 batts, and a 4Ah SDS also with 2 batts. Less than 300 for both. A charger and box each
Dewalt, T stak boxes
Discuss A good offer from Toolstation? in the Electrical Tools and Products area at ElectriciansForums.net
Those of you with apprentices might take a look...
They won't need to borrow your kit, and hopefully will be very happy with their own gear.
Plus...you can snaffle their batteries!
that's got 30 more torques than my AEG and the AEG is more than enough for most use. dewalt impact spades fly through normal wood on it. can't sayabout 200 year old oak timbers. might need a 110V for them.
Which is better then ,the Bosch or the the DeWalt impact spades ?
I've actually been testing one of the Irwins on the impact wrenchI have Dewalt spade bits - they're decent enough, but I don't think they're impact rated.
Irwin SpeedBor bits are also worth a look - those things tear through wood.
It's an old piece of furniture so I reckon the timber is pretty hard, gets through it though
I've started buying cheap SDS plus auger bits for the hilti 110v.
Got fed fed up messing about with SDS chuck adapters and keys
Sure sharpen them a few times and bin them then
ThanksI pick up the occasional new SDS Plus bit on ebay at bargain prices. Some really good branded, old stock for less than the price of new junk.
Recently picked up a couple of Reisser Zentro (4 cutter) - top notch German made gear. In fact here's one with stock still available, although not sure if you can still use the likes of Parcel Motel for delivery to IE.
THESE ARE WHAT I HAVE.I have Dewalt spade bits - they're decent enough, but I don't think they're impact rated.
DeWalt Extreme Impact Rated Flat Wood Drill Bit Set | Toolstation
Extra thick robust shank suitable for use with combi drils, drill drivers and impact drivers. Chamfered outer cutting spurs allow for clean, fast drilling and extended life. Set contains: 12, 16, 18, 20, 22, 25, 28 and 32mm bits.www.toolstation.com
Reply to A good offer from Toolstation? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
