Discuss Angles on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
Manufactured bends, then you can be as hacky as you like…..
I’ve got one of those tin snip type tools with a mitre plate. Leaves a clean edge, not all burred up that needs filed smooth.
4" battery Angle Dangle, chop chop, Bob's your auntie's sister.I’m doing a large install with PVC Trunking I had a Magnusson Mitre block but it’s not that great with a large hacksaw.
Does anyone have any recommendations on what to use and a decent saw?
If your wall is in any was shonky, even the slightest shonkiness, and mitred corners will be a pig unless you use CA glue and activator spray, which to be frank is a pain in the small donkey.Not a fan of the bends. They are okay in some places but I want to make this as neat as possible.
I can’t afford a multi tool and ive a junior hacksaw already. Only really good for cutting 90 degrees.mulitool and/or junior hacksaw.
Reply to Angles on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
