Search the forum,
Discuss Any suggestions for a shower in the Australia area at ElectriciansForums.net
Hi all,
After a bit of advice, we're having a garage built with an annexe above, the plan is to have a small bathroom with a shower in it. The problem is the water pressure is rubbish so just putting a standard electric shower in would result in being attacked by warm drizzle and I guess that you can't use an electric water pump. I don't particularly want the hassle or expense of having a hot water tank in there so I was wondering if anyone does an electric shower with a integral small pump.
All help gratefully received.
Down2earth
fit a header tank, then use a pump.
You can't pump mains pressured water, as above you'd need a header tank and then either pump that to a mixer or get the Mira above (or equiv)
yes you can, just not allowed to by water supplier.
just means neighbours' showers go cold, hee,hee. LOL.
Reply to Any suggestions for a shower in the Australia area at ElectriciansForums.net
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Dear Forum, I recently joined this forum, and writing for the first time. I like DIY activities, both for hobbies both to fix and repair stuff in...
