Search the forum,
Discuss Battery/solar/inverter system gives inaccurate power readings in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
Hi,
I have purchased a battery/inverter/solar system for my home. I also have a smart meter, and an app which links into my smart meter to get the power data from the smart meter.
The battery/solar/inverter system also tells me how much energy I am using. However, its readings are not accurate as the smart meter. Eg my smart meter tells me I am exporting 200W to the grid, but at this same time, my battery/solar/inverter system says its only 10W of export.
Why is this? Which battery/solar/inverter systems give accurate power readings?..accurate over the whole range of power, minumum to maximum.
Reply to Battery/solar/inverter system gives inaccurate power readings in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
I currently have a 3Kwh solar PV system which was installed over 12 years ago and getting a very good FIT payment and I don't want to lose it! I'm...
4K
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
Hi I currently on a job where the garage is having an office built above it with solar panels installed on the roof. I have ran a 16mm 3 core...
I have read all I can find about radio 4 and tele switching, but can't find if this changes when our clocks change. It all started when I decided...
