Discuss Buried cable in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I own but my neighbour has access over this drive. The supply will be in a plastic conduit about 40mm in diameter. My neighbour will complain if anything is wrong so it needs to be faultless. Any help please.
Thanks,
Glynn.
Can’t run t&e outside unless it’s mechanically protected entire route… (sunlight degrades the insulation)
Suggest armoured cable.
Also suggest bolting down “traffic calming” speed bump… comes in yellow and black sections. There’s a handy recess in the bottom can be used for a cable route.
Sounds like neighbour will be difficult if you start cutting a channel through the tarmac to bury the cable
I thought it was OPs tarmac, but neighbour has right of access over it.
If there's already animosity, the time you want to cut a channel is exactly the time mr neighbour wants to use it.
Poorly worded yes it is the OPs.
Hardly going to be a trench you couldn't drive over.
Reply to Buried cable in the UK Electrical Forum area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
