Search the forum,
Discuss Burying fiber in flexible conduit from house to garage in the DIY Electrical Advice area at ElectriciansForums.net
envy2578
Hello, I am burying a fiber optic cable so I have internet in my garage. I have purchased the following flexible conduit to run the fiber optic cable inside:
Diameter of the Kabuflex 40 mm.
*Inner diameter: 32 mm.
I have dug a 20m trench 60cm deep. What I need advice on is the transition from inside to outside. I don't want to drill a hole in the external wall large enough to feed to conduit through. I assume I need a junction box and adapter on the outside of the wall that the conduit connects with?
Fibre optic is specialist cable needing expensive tools to terminate properly.... would CAT6 data cable not work?
The cable is already terminated. Just needs care when pulling through conduit.
Buried Ethernet can cause equipment failure when there is a lightning strike.
Reply to Burying fiber in flexible conduit from house to garage in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hello I’m new to the forum (posting on it anyway). I could do with some advice... Over the last 2 years I have been subcontracted (labour only)...
