Search the forum,
Discuss Shower circuit converted to a new radial circuit in the DIY Electrical Advice area at ElectriciansForums.net
Alex87
Hi, I`m looking for an advice.
I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a 6mm cable and 40 amps fuse. The cable is quite newish (blue & brown) compared with the rest of the house (red & black).
I want to create a new radial circuit from above wire for 2 bedrooms ( 9 sockets +3 lights) can I just use it to connect it directly on a 2.5 mm cable via a 16 amp breaker or should I go for a mini Consumer unit( garage style) ?
The plan it`s to rewire whole house next year, but this is a temporarily measure to have electricity in the bedrooms while other works are carried in the house. Also the plan it`s to put flexible conduit (with 2.5twin and earth ) through the walls to be more easy in future.
Although you feasibly could use this as a 32A radial between the sockets, using the same size cable... and a fused connection unit before feeding any lights, sticking a garage board on the end of the 6mm and running a "standard" 32A, 2.5mm rfc and a 6A lighting circuit gives a bit of selectivity. It could all be left in when the future rewire commences.
Reply to Shower circuit converted to a new radial circuit in the DIY Electrical Advice area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Hello Electrical world. Looking for thoughts and opinions. Currently planning out my kitchen re-wire for new kitchen. I was originally...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
