Discuss Chilton single voltage (240) shaver socket replacement in the Electrical Tools and Products area at ElectriciansForums.net
F
FJR rider
Some expert insight needed please.
The Chilton 240 shaver socket in guest bathroom which is cosmetically good has failed and I cannot source a replacement. The unit is the old British format wider / shorter than modern units.
The unit has a 1:1 transformer switched on when needed by integral switch.
So to the question. Is there any reason why I cannot bypass transformer/ switch and make socket live permanently. I see no reason for the transformer in the first place and there is no integral fuse either.
appreciate comments or better still does anyone have 'new' old stock
Do not do that
Ah ah ... So the transformer is double wound type so can tolerate single fault . Got it
But if any one has a unit please let me know
Reply to Chilton single voltage (240) shaver socket replacement in the Electrical Tools and Products area at ElectriciansForums.net
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
My Current Setup (see image BEFORE.jpg): The wiring for my existing detached garage is shown (see image BEFORE.jpg). The house consumer unit...
Hi, Hoping someone can help me with a lighting circuit challenge. I have an existing two gang switch, with one 2C&E cable for a simple circuit...
6K
M
We are an electrical company aiming to provide affordable, reliable and competitive service to clients in and around the Preston and wider area...
mort2376
M
