Discuss compulsory E.I.C's for domestic properties? in the Electricians' Talk area at ElectriciansForums.net
I think it would actually be dangerous, disconnecting circuits every year continously year after year to test them could actually weaken the circuit breaker terminals and cause a fire lol.
And if socket outlets are unscrewed and then refitted there will be more metal-fatigue failures of the twin and earth. Specially if someone has nicked into the copper when it was stripped. Daz
As for the MOT analogy, a car weighs a ton travels 40 mph through town centre meters away from pedestrians. Your house doesn't create anywhere near the amount of hazards that your car does.
I have actually disconnected sockets in houses to conduct tests in the past when a fault has been on a ring, I split the ring to find which half the fault was on, when I tried to reconnect the socket after finding the fault the screws wouldn't tighten and I had to fit a new socket, so your point is not only valid it has been proven, good point Daz
I watched the guy doing a gas safe test on my flat yesterday. I know he didn’t cut corners, if fact he was very conscientious.
It took less than an hour, OK there’s only two appliances but he didn’t stint on what he did.
I’m due to have an EICR later this year. It could get interesting. I wonder how long that will take with me watching him to make sure he does what he’s paid to do?
:smilielol5:an electricians nightmare, I wouldn't want to carry out and EICR on your property with you watching, I would be so nervous I wouldn't be able to do the job lol
If he tries to put any visible stickers on the CU he’ll be on hospital food for a while.
Are you a time traveller MDJ? How did you reply to Tony's post before he posted it....
Reply to compulsory E.I.C's for domestic properties? in the Electricians' Talk area at ElectriciansForums.net
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Good afternoon one and all. I, like many non-electricians are having issues regarding the need to have domestic water pipes (plastic entry to the...
5K
  • Locked
5K
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
Electrician Jobs Domestic Electricians Wanted
RMS Facilities Management is looking for domestic electricians for the new build housing sector. Send your CVs to [email protected] Job title...
