P
paulsamuel1984
I was hoping someone could help with the following query....
Is there any additional protection that has to be incorporated if you connect PV onto an electrical system with a standby generator connected.
The DNO has advised that an additional G59 relay panel is not required at it is under 50kW and we propose g59/2 type inverters.
Can i connect the inverters as per normal? I assume that if the mains failed, the pV would automatically trip out and ould not run in parallel with the generator.
Any help?!!
Paul
Any help?!!
Paul
