Discuss CT clamp use in PV system in the DIY Electrical Advice area at ElectriciansForums.net
nbondb
I'm not going to touch it but I've a PV system installed that has CT clamp in supply meter. What does this do, why does it increase my import from grid?
In itself, it's not capable of increasing your import from the grid. If you're moving it and the reading is changing, that's to be expected (to an extent) because whilst CTs are pretty good, they are not as accurate as direct measurement.
What it does is convert a fluctuating magnetic field into a voltage that represents the current flowing in the cable it is clamped around.
It works because the magnetic field strength is proportional to the current flowing in the conductor and the voltage from the CT (which is essentially a coil of wire) is proportional to the field strength. So, higher voltage = higher current. Moving it will alter the field strength and thus it may appear to increase or decrease the current it is reading. The reality is it's not changing it, it's just exagerating the inaccuracy inherent in this measurement method.
Thanks. I'm not an electrician and have no intention of doing anything with it. The generation meter installed with my PV system shows more being imported than consumed within the home. The installers say it is because of the CT clamp. It is only about 0.5 kwh a day but it all costs!
Reply to CT clamp use in PV system in the DIY Electrical Advice area at ElectriciansForums.net
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Hi all, In July I had a PodPoint Solo installed at my house. It was a secondhand unit from my father in law. I've just recently realised it's...
I'm trying to find a way of energy logging a home to help plan a battery installation. Ideally tracking import by hour and displaying some...
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
