Discuss Diesel Fire Pumps in the Electrical Engineering Chat area at ElectriciansForums.net
Hello!
I have a diesel fire pump and jockey pump. The Article 695 by NEC is only for ELECTRIC Motor Fire Pumps? For diesel drive, the control panel must be connected like 695 article indicate? Or i can to connect the fire control panel with another load?
Reply to Diesel Fire Pumps in the Electrical Engineering Chat area at ElectriciansForums.net
I'm an electrical engineer in training so please bear with me. Basically, a bank has ordered a second 500kw diesel generator and my job is to...
Hey, I want to use an old xbox 360 PSU- 12V 175W output- for my 12V sup pump (pump/air compressor). When I connected the PSU to the pump...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi, I have very little electrical experience and would like a bit of advice. I have a kerosene pump installed in the back of my van. According to...
