Discuss DIY question: replacing dimmer switch with regular light switch in the UK Electrical Forum area at ElectriciansForums.net
Existing dimmer switch wiring in attached picture. Hot and neutral in, ground wire, extra red wire that, I believe, carries the signal voltage. This controls a dimmable LED overhead light fixture with only hot and neutral wires.
I want to replace the dimmer with a normal, single pole light switch.
Can I and, if so, how would it be wired?
I'm stumped, quite frankly.
Thanks!
It's probably hot and neutral in and controlled / switched hot out to the light. The new switch would connect between the supply hot and switched hot. The neutral would be left capped off with a wirenut as it is not needed.
Your existing switch looks to be three way, the two reds a likely to be travelers. Is there another switch controlling the same light. From what I can see there is no neutral at that switch.
Reply to DIY question: replacing dimmer switch with regular light switch in the UK Electrical Forum area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
