Discuss Dimmer Switch - LED in the DIY Electrical Advice area at ElectriciansForums.net
jgodfrey
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot and the red wire was in L1 which i thought odd because i thought it needed to be the other way around. Anyway as it had worked for so long that way around I wired the new dimmer the same way, black in common and red in L1 and for a few days lights working well. 4 LED bathroom spotlights and one extractor. however now they are flickering and then switching off. Should i swap the wiring around?
Reply to Dimmer Switch - LED in the DIY Electrical Advice area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Novice here wondering what I might be missing. Thanks for any help. I am swapping out an old switch in the bathroom to a dimmer switch. When I...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
