Search the forum,
Discuss Emergency Lighting questions in the UK Electrical Forum area at ElectriciansForums.net
Hi, going to be doing a few emergency lighting installations (non-maintained) and just need some clarification on the paperwork that needs to be issued.
Have read the IET guide to emergency lighting which didnt quite clarify everything.
from what I can see I need to issue :
1- Emergency Lighting Completion Certificate
2 - Design - Declaration of Conformity
3 - Installation - Declaration of Conformity
4. Verification -Declaration of Conformity
I know I also have to make a log book available, in a small domestic HMO (4 rooms) can this be an a4 sheet I make up myself and place in position? as it will only need annual testing?
Also, the "photometric data" that needs to be issued isn't really explained. Is this data on the lights that have been installed (simply from the manufacturer) or is it more complex calculations based on the system you create.
Thanks in advance for any help
Mark
The scam you are registered with, will have the certs, Design, install & commission....variation is only required if design is altered from BS5266.
EM`s will require 1 x 20 minute test and 1 x 3hr discharge test per year.
With HMO, the design will be done by BC when appying for the licence.
Thanks, ill be making up my own certs. When you say the design will be done by BC do you mean the design certificate, the photometric design data or both?
If your working on a HMO, building control (Local Council) will inspect the premises, prior to issuing a HMO licence. The will state with basic drawings what they require, fire alarm, em lighting, extinguishers, fire blankets, fire doors etc...When the inspect the final work they will pass the premises. Word of warning, don`t start work until they have given jobs to be completed first.
ah, ok they haven't on this occasion, they have just stated they need an "Emergency lighting system conforming to BS 5226"
I was under the impression by your post, as well a Doomed, you were after cert help.
The two things I need help with is clarification on what is required in terms of "Photometric data"
and if a log book can just consist of a piece of paper to keep track of testing etc
Reply to Emergency Lighting questions in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi little lost on a question for lvl 4 design verification Can anyone guide me to any calculations or formulas Its for a 4.35m x 2.8m plant room...
