- Reaction score
- 2,441
I have a job coming up where I likely need to replace old twin and earth (imperial size) feeding one, perhaps two flats in a 3 storey converted building.
The ground floor is a separate front entrance, the upper flats have a side entrance with stairwell, which is protected with smoke and EL, though not sure if a FRA exists, or if it counts as a protected escape route (there is an external metal staircase as well).
The current T&E is buried in the wall, but for ease/cost I'd like to surface mount from the meters (under the stairs at ground level) and up to the flat.
My current thinking is SWA surface clipped with Dline or Linian clips. Obviously there will be a suitable fuse in the meter cupboard to protect the run.
Anyone see an issue with that and feel an alternative is better or required (steel trunking for example)? I haven't worked with steel conduit or MICC so would rather this wasn't the job to start on...
If I go with SWA, should I be sourcing BS 7846 fire resistant cabling? If so, anyone know of a wholesaler that sells it by the metre?
