Discuss FP Cable Is Not Always Suitable in the Electricians' Talk area at ElectriciansForums.net
The last lad I trained asked about pyro at college and was told they didn't do it any more as it was a bit of a black art eventually I can see it being a specialised thing if something isn't done to improve training at college,lets be honest it's still widely used in certain areas so should still be taught as part of normal trade training.
I was taught the same way mate as many others will as its good practice. I had a conversation with a guy from Cormeton once who was commissioning a fire alarm system that had been extended from pyro to fp and he said ut can cause problems. Cant remember the reason he gave I think it was on an adressable system so may have been something to do with the systems knows which way accessories or set at or something along those lines. (Im not mega clued up on the technical side of fire alarms)
That sounds like a bit of old bull to get around him being unable or too lazy to do it properly.
It's easy enough to get the polarity right on a bit of pyro, and I'm sure a earthed solid copper sheath is better than a bit of tin foil wrapped around the cores as far as screening goes.
first attempt at 2l1.5 using double pliers method
lovely stuff to work with, I don't know why some people really don't like it
How did you get the seal crimped into the pot without stripping a bit more sheath back to get the crimped round it?
It may be an optical illusion but it doesn't look like you've stripped enough sheath back to me
yup your right, I havent actually threaded it as far as I should have.
its caught a little bit of thread but I didnt realise how far it was supposed to go till I just did more research on youtube.
What dave means is you need to strip back more orange sheath so you can slide the gland back, you need to crimp the cap into the pot firmly, you can't do that with the gland in the way fella.
true, to be honest Its a bodge at home till I get hold of a crimper.
I crimped it into the pot by putting one side of the grips on the very bottom on the gland and the other side on the top of the pot.
I would like to have used a proper crimper but I don't have access to one at the moment
aye I know pal, bear with me.
Reply to FP Cable Is Not Always Suitable in the Electricians' Talk area at ElectriciansForums.net
I was tracing some electrical cabling last night and noticed a ~6" section of 2.5 T&E cable that appears to have been subject to heat damage and...
Hello all I'm doing a Job in France for my company where we are installing SWA for power to our own control panels The issue is the DB is a...
9K
Silly Sausage
I have a goods lift where I work which is being overhauled, part of which will involve some rewiring of the control circuits to upgrade the...
I'm a Facilities Manager and not an electrician though I do have some electrical qualifications of some years ago. I wonder if anyone would like...
8K
