Discuss FP Cable Is Not Always Suitable in the Electricians' Talk area at ElectriciansForums.net
when you screw the pot on you only want the bare cable sheath to just be level with the top of the threads inside the pot, I always pull the cores with a pair of pliers before adding compound and blow out the powder so the pot is clean and dust free. When you get a crimper which hopefully will be early next week you need to ensure the gland slides back away from the pot so you can really get arount the whole pot to crimp it up tight, apart from a couple of basic mistakes your attempt looks good, it is straight and the cores look in good condition, practice makes perfect :rockon:
attempt 2 so far
ill leave the compound off till I get a potting tool.
im going to take into work in the morning then ill ir it. (im at home and dont have an ir tester)
Looks good from here, cable sheath just half a gnats whisker inside the pot and the earth tail in the right position relative to the cores.
Grab the end of the cores with a pair of pliers and give them a good hard tug to straighten then out, it'll make sliding the seal on a tad easier.
didnt realise it was so ****ed
afterall ****ed is the new straight, feel free to call me neville XD
Not bad for a first attempt, I've seen a lot worse. Did you IR it?
You probably saw one of my first attempts Trev!! Got a right ear-bashing for it... no shroud, pot not straight and screwed on to far...
btw - I've a spare one of these if MDJ can't set you up...
Edit - didn't realize the pic was that big, i'ts only for 20mm pots :)
As an apprentice I was given scrap ends to make off, After a while and some intense inspections of my efforts I was allowed to use potting compound. The first end I made off that actually went into service made me a very proud puppy spark.
Afaik it's still there to this day.
Reply to FP Cable Is Not Always Suitable in the Electricians' Talk area at ElectriciansForums.net
I was tracing some electrical cabling last night and noticed a ~6" section of 2.5 T&E cable that appears to have been subject to heat damage and...
Hello all I'm doing a Job in France for my company where we are installing SWA for power to our own control panels The issue is the DB is a...
9K
Silly Sausage
I have a goods lift where I work which is being overhauled, part of which will involve some rewiring of the control circuits to upgrade the...
I'm a Facilities Manager and not an electrician though I do have some electrical qualifications of some years ago. I wonder if anyone would like...
8K
