Discuss GFCI tripping EV charger CCID in the DIY Electrical Advice area at ElectriciansForums.net
Jdaa1227
I have an issue with the GFCI breaker that was installed by my local electrician. It is not supposed to be installed with a charging circuit interrupting device (CCID) protection that is my charge point homeflex EV charger. Especially if using a plug.
I would love to just replace it with a 3 pole 50amp GE breaker (non-gfci) that I can run all three wires into it. Meaning I don’t have to run wires to different places. However I don’t know what to order and would like to not make this complicated.
Calling the electrician back is not an option.
Reply to GFCI tripping EV charger CCID in the DIY Electrical Advice area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I note that in answer to another EV Charger question a member suggested a 40A breaker would be preferred to a 32A because of many hours at...
I am an NICEIC contractor but I have never installed an Electric vehicle charger. I have watched all of the relevant NICEIC webinars (The wire) on...
Hello, I have a EV charger that is reporting over voltage and is unable to charge. the charger will operate up to 253V The solar inverter reports...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
