Discuss Good Morning Thread - Come say good morning, tell us what you've got on today. :) in the The Electrical Exchange area at ElectriciansForums.net
The boss is making me work replying to threads and emails on all the forums. Barely a week till the big day now - is everyone looking forward to a little break?
Lou. lost my notifications from top of page. they come up for a second when I select a thread or forum, then the top header of the page changes and they sre gone.
Bumpity bump….
Been at my brothers in Edinburgh today for a covid safe gift exchange… and I forgot he had this item. I’ve blanked out the artist name from the ticket as a little game, but he stole this running list from the front of the stage at the end.
Along with a pair of drumsticks
Bumpity bump….
Dave called and said he'd like those sticks back.
To make matters worse my backup troubleshooting Megger is on the blink , hopefully it's just batteries ,only a few weeks since my Eagle Megger packed up
I have the same backup Megger BM. It's the backup-backup now really but occasionally saves the day. I grab it without a 2nd thought if I'm breaking down a ring, or for pre-CU change IR tests.
I'd try a clean of the contacts on the selector switch. In my view it's well worth keeping it alive, they are great little testers, and I'm sure it will still be working come the day my Kewtech and my Metrel give up!
Stayed in this morning for open reach engineer, broadband had been cutting out and buffering… so now got a new phone master socket, and about 20Mb/s faster. (60 up to 80)
Good enough for what I need.
During that I got a phone call.
“Could you come and have a look. Main fuse blew and Scottish Power said to get an electrician to look at it. Dead short”
I wonder what could be wrong here? The 40 and 50 at RHS look like they’re splitting apart.
I assume the 63A RCD is the mainswitch.
Other question. What’s the best solution? Replace rcd for 100A? Possibly been changed before as it’s not same make.
Will push for new DB, but need a short term fix for xmas
Obviously dead short needs finding!
I'd imagine them splitting apart is a result of thermal damage/overload and/or being under mechanical strain - I'd first check for loose connections on the shower circuit at the board, pull cord and shower.
Very short term - given Hager is seemingly a close fits you could probably acquire a new set of Hager MCB's and new bus bar for minimal cost and pop them in.
I'm also wondering if by the time you have identified the fault and disconnected most things finding it a board change afterwards would be quicker!
(I wouldn't be changing RCD for 100A without consideration of supplier fuse, tails, and max demand and don't see it as a solution to the dead short or the deformed breakers)
Getting on site, I see there was some details missing…. Like the other half of the board. Customer sent the first pic.
So RCD looks a bit black, as does the 50 and 40….
As a stop gap before Xmas, I cannibalised a new Wylex board and replaced everything on the left.
There was a dead short on the feed to the rcd…. Insulation melted through, blowing the main fuse. SP replaced a 100A with an 80 for some reason. The switch fuse supplying the Swa to here has a 100 in it.
Customer said the fuse blew when the shower was on, AND the oven… so I thought simple overload. Left shower disconnected as I didn’t have a wylex that size.
Turns out their boiler is electric… takes 12kW and is on same 50A mcb as the shower.
Will be getting a board change out of this, but after new year.
Reply to Good Morning Thread - Come say good morning, tell us what you've got on today. :) in the The Electrical Exchange area at ElectriciansForums.net
What's the most badly designed accessory you've had to install? I present my nomination, the ML Accessories/Knightsbridge RWL5 wall-mounted LED...
Merry Christmas from ElectriciansForums.net What a weird year we’ve had! We will need to keep our wits about us during these next couple of...
5K
Just venting a little.... At 2:45pm I'd finished another job early. So I thought I'd have an initial look around a really small 2 bed bungalow...
Electrical News | Electricians News - News and Articles for the Electrical Industry News and Articles for the Electrical Industry - Electrical...
6K
I'm hoping someone out there has come across this problem. Just had -8 days ago- a 6k solar panel system plus 4.8k battery pack installed. When...
9K
