I guess that is the minimum. mostly I have used metal box grid switches and they are tight....35mm back box no problem.
Discuss Grid Switches radial wiring acceptable or not? in the Electrical Tools and Products area at ElectriciansForums.net
Yes definitely always use a 35mm deep box as a minimum but 47mm definitely makes life easier as can be a bit of faff in 35mm but not an issue if cut to length and dressed neatlyI guess that is the minimum. mostly I have used metal box grid switches and they are tight.
Flat plate grid dimmers spring to mind.They are never deep enough!
Reply to Grid Switches radial wiring acceptable or not? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
