Discuss Hi guys l just wanted to ask a question in the UK Electrical Forum area at ElectriciansForums.net
I’d say it’d depend on whether you intend to use the low smoke white sheathed T&E, or the old obsolete white sheathed with red and black insulation on the conductors.
I assume it's either white pvc,or white lsf in new colours, both are ok.
There is no restriction in the colours (of the outer sheath) that may be used.
Although, if you are wiring smoke alarms, you ought to use a different colour than other circuits, it is common to use red 3c+E; but this isn't available in twin and earth only grey and white.
It is white sheathed t&e lsf l think this type of cable is mostly used in commercial properties rather than domestic l was just curoius if it is allowed to be used in domestic a friend is building an extention and it happen that he has got a few drums of that type of cable and doesnt know if he can use it or not,
It’ll be absolutely fine to use.
There is no restriction in the colours that may be used.
It is white sheathed t&e lsf new colours, l think this type of cable is mostly used in commercial properties rather than domestic l was just curoius if it is allowed to be used in domestic a friend is building an extention and it happen that he has got a few drums of that type of cable and doesnt know if he can use it or not,
Perfectly fine, in fact lsf is probably better/safer than pvc, although either could be used.
The difference in price is next to nothing, used to like working with white T&E good for the surface jobs, alas its frowned upon these days to clip direct surface, got to use mini turk.!!
Reply to Hi guys l just wanted to ask a question in the UK Electrical Forum area at ElectriciansForums.net
Hi. I live in an older house and I have old white twin and earth cables going through walls in large white pipes. Unfortunately, some mice managed...
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
HI , potential 2 bed 1970’s bungalow buyer here…. Our surveyor (RICS) has pointed out there is no circuit breaker to the electrics (fuse board...
