Search the forum,
Discuss Hilti ME fixer in the Electrical Tools and Products area at ElectriciansForums.net
marc8
Hello just been looking at hilti ME fixer for concrete ceilings & just wanted to know if anybody had used on for fitting conduit (metal) as they do conduit fitting's, they do conduit saddles so was not sure.
expensive but if you have long runs and a lazer line 100%. If you buy enough of them you get the gun for free. For basket, ladder and tray 101% wouldn't do it any other way.
Hello
just about to purchase in next week or so we have a carpark to do just wasn't sure you could do the metal conduit with it was unsure if it would mis shape the conduit say you had two stop end boxes one each end then use the Hilti unit to fix the stop ends then support the conduit length any problems or does it work like that
If it's the gas-actuated Hilti tool then I generally only use it for fixings for cable ties - although it's extremely handy. If I was doing conduit then I would just use traditional saddles e.g. spacer bar saddles.
Reply to Hilti ME fixer in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I have been looking for a hilti Ca 7/36 battery adapter or a TCU 22H 120v charger or a TCU 12/24M 120v charger. Without one of the above I am...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
I know I’ve seen them before…. But I can’t think of a name. I’m needing a line of metal back boxes in a kitchen… 2 lots of 2x 2 gang and a 1...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
