kreatiff63
- Reaction score
- 8
How do you decommission a light switch? I don't want to use a cover plate. Any ideas ?
Discuss How do you decommission a light switch? Any ideas? in the DIY Electrical Advice area at ElectriciansForums.net
As above, but remove the box completely, as wet plaster will rust a metal box and will eventually come through to the surface.Disconnect the cable at source, and ideally remove it completely, then plaster over the box.
It's not working.Disconnect the cable at source, and ideally remove it completely, then plaster over the box.
It's not working.
Reply to How do you decommission a light switch? Any ideas? in the DIY Electrical Advice area at ElectriciansForums.net
