Search the forum,
Discuss How to make a 20 LED chaser with 4017 ? in the DIY Electrical Advice area at ElectriciansForums.net
_q12x_
But only 1 led at a time and counting from 0 to 20.
The 4017 can do a 10 LED chaser on its own. You use daisy chain more than one 4017 together by connecting the last output of the 1st IC to feed the clock input of the 2nd.
So you mean like this, right?
But is not sequentially !
When A is clocking B is not doing it sequentially, meaning 1 after 1 (or one after another), but binary,
meaning when A is finishing a pass, it will increment B with 1 and then A will start another round.
It is counting 0123456789 in A then 11 in B. (since 10 was lit up until this time) then again 0123456789
in A then 12 in B (since 11 was lit up until this time) and so on.
All I want is an incremental and cursive 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
Reply to How to make a 20 LED chaser with 4017 ? in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi everyone. I should start by saying I'm not sure I'm in the right place here (this isn't a householder issue - I'm making a Ghostbusters...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I bought a ceiling fan with LED lights. After some time the led lights started flashing when I put them on. Now it does not even jump up anymore...
