Discuss How to use a Lipo battery to power a carcam in the DIY Electrical Advice area at ElectriciansForums.net
Hello
I am hoping someone can point me in the right direction. I have 4 x new Lipo rechargeable batteries 2900mAh 11.1v (32Wh) 35C constant and 65c discharge bursts (?? pass!). I would like to use them to power a car cam (not being used for a car) which has a micro power connection (like a USB with a kink) Can it be done as the cables are different sizes. I would appreciate advice so much as I havent a clue.
If the overall voltage from the batteries is 11.1V then you should be fine to feed this into a standard car dashcam power adaptor - this will regulate the voltage down to the 5V that the camera needs.
Fantastic. Thank you very much DPG!
Reply to How to use a Lipo battery to power a carcam in the DIY Electrical Advice area at ElectriciansForums.net
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave...
We have a 5.5kW incoming supply, which cannot practicably be upgraded due to our remote location in the mountains. Can I use a PV array and...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
