Search the forum,
Discuss I always thought heat pumps were expensive waste of time in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
well presented video. nail on head. 50 characters agin. gordon bennet.
Let’s face it, gas boilers are on The way out , it’s just a matter of time.
2030 ? Is that the date for no more gas boiler installs ?
50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 FFFFIIIIIIFFFFFFTTTTTTTTYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
I have electric heating, a mix of storage radiators and oil-filled wall-hung ones. No gas supply is available. The storage rads are hardly ever on, usually only between November and March, and only every second day. Insulation levels are very good in the house.
Looking at that video, and assuming a cost to me at the lower level, actually about £8k in my case, after grant assistance, I could buy about 6 or 7 years worth of electricity at my current rate for that outlay. By then, I might be dead...
Of course, even if I did install a heat pump and spent that capital cost upfront, I am still going to have ongoing electricity bills because I will need electricity to run the fan etc and for cooking. I would also have to factor in the cost of replacing the heat pump unit/fan/whatever else might fail.
I have been bombarded recently with leaflets urging me to replace my old storage rads with new, high-efficiency ones. I have resisted this as my ancient ones, although hardly Lot20 standard, are working fine, provide more than enough heat for my needs, and the cost of new ones would be enough to pay for electricity to heat my old ones for a few years.
That's just my personal situation and viewpoint, but I suspect many others are in a similar situation, whereby a heat pump simply isn't an option nor a solution. For me, it's not a question of substituting a heat pump for a gas boiler, just changing how electricity is provided to heat my home.
Other problems arise because I live in a flatted development, so consent of the other owners would be required prior to installing a pump on the outside wall. I have no doubt whatsoever that the other owners would consent, provided the pump was installed on the rear of the block rather than the front elevation, or even on the flat roof, but the rear garden is landscaped and on a slope so I can imagine the cost of scaffolding would be considerable, not only for the original installation but also for any ongoing maintenance/repair.
I can't see this technology working for me. Good insulation is paramount, and basic additional insulation would be much cheaper in many instances. Now, where's my super-glue...?
Surprising that not more comment on this as it affects us all and especially the next generations. The cost of gas going up as per wholesale prices. Fuel poverty is not far off. I expect many elderly will die this winter due to fuel poverty in this country. So the gov. are rolling out disastrously expensive "solutions" that will turn out to be non-solutions and we go quietly into that dark night literally.
Nice Dylan Thomas reference there!
Reply to I always thought heat pumps were expensive waste of time in the Green Energy Forums | Green Energy Hub area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Seriously just wanting to have a discussion on this huge issue. Clearly, there are not enough competent installers of heat pumps, so we may see...
Hi, I have a Beko DHR73431W heat pump tumble dryer that isn't heating. I'm thinking its beyond economic repair as I think the compressor has gone...
Friend asked me to wire in a hive on a conventional 1 zone heating system. So I fitted it tested the HIVE and all was working. I then said to him...
