Discuss I got an electric shock in the UK Electrical Forum area at ElectriciansForums.net
Hi, changed a bathroom extractor fan. Easy enough.
I was dealing with a grey, black, brown and earth wire.
When i tested the black wire, which i believe is neutral, with a electrical tester screwdriver which i poked into the connection I got a electric shock.
Weird. as soon as i touched the metal shower frame i got a shock. Not sure why. Can someone please explain. The earth was live too and not connected.
Black WAS neutral, but after the colour changes circa 2005, black is now line conductor.
Grey is most likely the neutral.
Make a note of how the old fan was connected before removal.
If you got a shock from the metal shower frame.
there is only one piece of advice I can give you, please follow it to the letter before someone dies.
1. TURN OFF THE SUPPLY TO THE BUILDING, It will be a red switch and should be marked "Main Switch" or similar
2. CALL IN AN ELECTRICIAN THAT IS REGISTERED FOR DOMESTIC WORK
3. DO NOT TURN ON THE POWER UNTIL THEY (Qualified Electrician) HAVE DEEMED IT SAFE
p.s. about the above post.
I realise it was only a short and to the point post and you might think I am trying to scare you into spending some money or that I am making a mountain out of a mole hill.
however, the risk of death from electrocution is raised by a huge amount when bare skin and water get involved.
the fact you survived your electric shock from the shower may well be a combination of wearing clothing, footwear, and luck.
someone covered in water and trying to grab hold of anything to stop them falling is likely to be FATAL.
you said you got a shock but did not mention that any protective device had tripped makes me even more concerned that there may not be adequate protection against shock in a bathroom.
I am not scare mongering, PLEASE GET IT SORTED BEFORE you are in court for manslaughter or something similar.
Were you holding onto the shower frame and touching the black wire terminal at the same time?
If you intend to do any more electrical work then I would advise in getting a two pole voltage tester and a proving unit. Then ensure you know the correct safe isolation procedure.
Definitely better to be safe than sorry as this incident proves.
How bad was the shock? You may need to consider seeking medical advice - some shocks can cause heart problems which aren't initially apparent.
Is this the same fan you were asking about in your other thread back in January?
Well at least the fan worked so it was all worth it in the end. Don’t know why people bother with college for all this easy stuff, all you need is a neon screwdriver and a strong heart.
Reply to I got an electric shock in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
