Discuss I need help with LED light strips. I have a 120v 10a ac/dc power source. A led controller that can handle the power and output. in the Lighting Forum area at ElectriciansForums.net
Landin
As the title says.
But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug and play and I wanted to attach the next one to the strip at the end so they work on the same command. It's all going into a party bus so there is a 5-6ft gap where I was going to use wires across the back to connect/bridge them together. The second string won't work at all aside from a couple lights on the strip. I've tried so many different things but I'm hitting a wall now
Try a new setup, strip may be damaged, cannot really offer much from the details I'm afraid. Did you cut when live? Transformer may be damaged. Another option may be witchcraft, have you been cursed by a friend or relative (maybe there is a doll with pins in it at a friends house? I find its one of those three for most electrical issues.
Reply to I need help with LED light strips. I have a 120v 10a ac/dc power source. A led controller that can handle the power and output. in the Lighting Forum area at ElectriciansForums.net
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
