Search the forum,
Discuss Indoor outdoor wire for indoor to outdoor back indoor in the DIY Electrical Advice area at ElectriciansForums.net
I need to run a electric wire from the garage to outside against the house and back into the kitchen for a stove can I just use a outdoor wire and strap it to the house siding our do I need a conduit.
Cable needs to be specified for the worst environment it passes through.
I guess my question is why are you feeding the stove from the garage. Please be more specific. The NEC states that if the wire is subject to physical damage then it is required to be in conduit. As stated above the wire needs to be approved for wet locations.
Reactions: DPG
The breaker panel is in the garage currently no 220 outlet for an electric stove we currently use a gas stove so want to run the wire to outside and over to kitchen. I have a raised ranch so kitchen is on upper level
my choice would be SWA, suitably cleated and glanded at both ends. Using the armour as cpc or having a separate cpc
Reply to Indoor outdoor wire for indoor to outdoor back indoor in the DIY Electrical Advice area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Forgive me if this is easy to search - I was not able to find anything obvious here or on YouTube. I've got an outdoor circuit that has failed...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
I guess there are a thousand question like this, but I couldn't quite get if I can do this myself or need an electrician. I have a garage...
