Search the forum,
Discuss Regulations Question UK outdoor socket in the DIY Electrical Advice area at ElectriciansForums.net
sebasb21
I guess there are a thousand question like this, but I couldn't quite get if I can do this myself or need an electrician.
I have a garage separated from the house that has it's own supply (a big armoured cable that comes from the house) that goes into a 10A RCBO (exactly this guy: GE DP100 Single Pole & Neutral RCBO C Curve 10A 30mA Type AC - https://www.ilecsys.co.uk/distribution-protection/ge/dp100/dp100c10-030-609706). After that the circuit goes to indoor sockets, lights and also goes Outside the garage through a wall to a light.
Can I continue that outside light circuit to add an outdoor socket? Or I need an electrician to do it?
I was planning on either just continue the circuit into a small conduit to 20 or 30 cm from the ground and then put the socket there. Or maybe remove the light put a box, install the same light right to it and then conduit from the box to the socket above ground level.
Thanks!
Seb
Reply to Regulations Question UK outdoor socket in the DIY Electrical Advice area at ElectriciansForums.net
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello. I live in a new build house with a separate garage. The garage is connected to RCD in the house to a 16A circuit breaker. The cable from...
I need to run a electric wire from the garage to outside against the house and back into the kitchen for a stove can I just use a outdoor wire and...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
