Discuss Induced voltage on neutral wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone,
When checking my consumer unit voltages with the full board off, I stumbled across something head scratching.
Measuring the feed from the DNO, L-N I read 242.3 V. Measuring L-E I measured 242.3 V and N-E I measured a steady 30 mV.
When measuring the live side of the main of the main switch to the dead side of the main switch, I measured 55 V. This as you see in substations is impressed Voltage. At least so I believe.
The head scratching thing I found, is that with each final circuits neutral wire disconnected from the consumer unit (but earth wires connected and live wires connected to the open MCBs (fed from two open RCDs)) I found that each circuits Neutral wire measured 240 V with respect to the DNO Live.
as each of these circuits has appliances in, the only thing I can think of, is that im measuring again an impressed Voltage on the neutral through the cabling and through the appliances, socket ring, light radial etc.
Is this a normal occurance? Anyone come across this before?
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E.
this could give you a true voltage reading as you were getting.
Reply to Induced voltage on neutral wire in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
all currently working towards my 2391 c&g I&T . I know how to calculate v.d. but the mock test I found online seems a bit out of date or I'm...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hi, I've got a light with a ceiling rose in the kitchen. While rectifying some faults in the house I came across to the light and measure Neutral...
5K
