Discuss Install a 3-way toggle switch and outlet at top of the staircase... in the DIY Electrical Advice area at ElectriciansForums.net
cheesch
Hello everyone...
There are a total of 4 cables entering the junction box at the top of the staircase.
Two 12/2 cables are coming in through the top of the box.
One 12/2 cable is coming through the bottom of the box, with a 12/3 cable coming through beside it.
The three 12/2 cables have their whites together with a wire nut.
Two of the 12/2 cables have their black wires attached to the black wire of the 12/3 cable with a wire nut.
So that leaves one of the 12/2 cable's black wire available for use on a switch, and the red wire and the white wire coming from the 12/3 cable available for attaching to a switch.
The box at the bottom of the staircase has one 12/3 cable entering it.
At the top of the stairs I would like to install a 3-Way Toggle Switch and Receptacle with the Receptacle always hot.
At the bottom of the stairs, a regular 3-way switch is already installed...
With what I have described can I do this install successfully?
And if yes, what wires would be used to connect to the 3-way combo switch/receptacle in order for it to work and also have the outlet always hot.
OneDrive Here are some photos, thank you for very much for your assistance!
Hello everyone...
I found out the answer from another forum...here it is,
yes
This will be your neutral for the receptacle. Add a pigtail and connect to silver screw.
This is your hot wire. Disconnect from 12/3 black and connect to common on the switch combo device with a black pigtail.
Connect this black to the black from the 12/3 you disconnected above.
Connect to the traveller screws of the combo device.
Reply to Install a 3-way toggle switch and outlet at top of the staircase... in the DIY Electrical Advice area at ElectriciansForums.net
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
I have a staircase about 25 feet long with two recessed lights (one up top, the other at the bottom). Each light is on its own 3-way switch, which...
I usually always take a picture before disconnecting electrical wiring and this time I did not. I am trying to wire a 3way switch that controls...
Hi everyone. I bought one of those smart switches, specifically the Kasa 3 way kit (HS210 KIT). But when I opened my 3 way dumb switches I see...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
