Search the forum,
Discuss Megger LT3 MK2 Tester in the Electrical Tools and Products area at ElectriciansForums.net
I’m trying to find an instruction manual/wiring diagram for an old Megger/Evershed Vignoles LT3 MK2 Earth Loop tester ….any info would be appreciated….
The L-E and L-N indic.lights are self explanator,but how is the probe connected?
if the tester were plugged into a socket and the probe was touched onto a remote metallic earthed device would it register the validity of the earthing of the device?
From memory it tests the socket earth if a probe isn't connected, and uses the probe instead if you plug it in.
These days in most cases it will instantly trip an RCD if you use it, unless you use an socket that isn't RCD protected.
Look at youtube - "John Ward" for videos on earth loop impedance testing in general.
For how to test an RCD protected circuit with a high current test, this video shows the principle:
It would be hard to do safely with your particular machine though.
Reply to Megger LT3 MK2 Tester in the Electrical Tools and Products area at ElectriciansForums.net
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
I've managed to mainly fix a Megger 1502 MFT that was so far out of calibration it got laughed out of a tester day. I have high current loop. rcd...
Hello everyone, I’m based in the ROI and live in a rural location. Yesterday evening my electricity supply started to switch on and off randomly...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
First off, I'm clearly not an electrician and I'm sure the answer is simple, but I didn't want to go messing with the wires without being sure. I...
