Search the forum,
Discuss Minor Works Cert - No CPC in the Australia area at ElectriciansForums.net
I've just installed a couple of additional 12v down lights and changed extractor fan in a bathroom. The lighting circuit is one with no CPC.
How would you complete a MEW?
Obviously tests are limited in this case, but where would you use LIM, X, - etc in the relevant boxes?
thanks.
Sorry Wicks but you need to supply an earth/cpc to the accessories in a bathroom plus ensure they are IP rated with a Zs that is needed.
No earth/cpc = don't add on. Unless you supply the cpc.
Just finished job. Stuck in CPC regardless and tested as normal.
Does seen a little pointless. Only existing wiring was used and all accessores are class 2. So I have just earthed a joint box.
Makes testing easier and have reccomended upgrade, so may bring more work eventually.
Every Cloud........
P.S. Thanks for the reply Paul.
Reply to Minor Works Cert - No CPC in the Australia area at ElectriciansForums.net
I put some news lights in a bathroom and new extractor fan. Did the tests and filled out form. A couple of days later another electrician came in...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
