Search the forum,
Discuss Moving cables and sockets/switches over insulation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Camerart
Hi,
I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall.
I understand this will derate the cable, so what it the best way to do this please?
EDIT: Should be in DIY
Camerart
WELCOME I have had the thread moved
Hi,
Camerart
You'll have to give some more info! Is it that you have an existing wall with existing cable and socket, and that you're basically just adding insulation over the top?
Reply to Moving cables and sockets/switches over insulation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
