Search the forum,
Discuss Neutral to Earth is live (230v) in my distribution board?! in the UK Electrical Forum area at ElectriciansForums.net
Has anyone experienced this before?
The neutral bar is live.. nothing had tripped and everything works fine in the property.
any ideas?
What's the voltage between line and earth? Some pictures of the service cutout, meter and the connection to the board might be interesting.
This is dangerous as your circuit breakers are likely single pole and only in the line conductors, ads won't occur with current flowing between neutral to earth.
any ideas?
How have you confirmed that it is the neutral bar that is live and not the earth?
What did you use to make this voltage measurement and did you measure the voltage between any other points?
You need a live-neutral, live-earth and neutral-earth measurement to make sense of this.
Reply to Neutral to Earth is live (230v) in my distribution board?! in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
