Discuss No LB when transitioning pvc up from trench into subpanel through wall in the UK Electrical Forum area at ElectriciansForums.net
Acort002
I have an electrician installing new circuit from my existing panel to a new subpanel in my detached garage. The subpanel is in the inside wall of the garage. The installation is underground with 1.5" conduit. Instead of using an LB on the outside wall of the garage, the electrician heated a piece of the pvc to bend it and installed it directly up from the trench through the garage stucco wall into the subpanel. Typically ive seen an LB to transition from outside to inside. Is this install seem right?
You are right my friend and I bet it looks like s—t. I do one of 2 things which is install an LB or a junction box on both sides of the wall. Make him change it
Reply to No LB when transitioning pvc up from trench into subpanel through wall in the UK Electrical Forum area at ElectriciansForums.net
I am connecting a manual transfer switch to a subpanel. In order to minimize drywall work, I am mounting the transfer switch to the surface of the...
I am building a duplex. The service enters the house through the wall of one of the units, where the main panels for both units are located. Then...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hello, I am burying a fiber optic cable so I have internet in my garage. I have purchased the following flexible conduit to run the fiber optic...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
