Currently reading:
Outdoor pir lights
Discuss Outdoor pir lights in the Lighting Forum area at ElectriciansForums.net
all delends on how it's wired. if you have a neutral at the switch, then you can go straight from the switch( i'm assuming that the switch is to turn the existing PIR light on and off (isolate) rather than to manually override the PIR)).
what kind of light is it led or halogen ?
Thanks for the reply. Its a halogen
[automerge]1590079437[/automerge]
Thanks for the reply, Yes there is a neutral at the switch, so I am thinking I am ok to do that then
Reply to Outdoor pir lights in the Lighting Forum area at ElectriciansForums.net
