Discuss Outside Light with built in PIR in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Heavy industrial spark here, never do house bashing hence the question.
I currently have a light switch at the front door not doing anything at the moment.
I wish to take a cable, a 2 core and earth from it to an outside built in PIR activation light then daisy chain the wiring to another two built in PIR activated lights. I understand I might have to use JBs at each as I will have a pre made flex and two mains legs at a couple.
Will this work? Will each light just switch on individually when each PIR is activated?
Some pir lights have a switched output so you can link them together, when any pir is activated then all lights will come on.
if you don’t connect that cable then they will all work as individual pir lights.
just check that you have a N at the light switch before buying any materials.
Reply to Outside Light with built in PIR in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Ok so I have a quinetic switch connected to a relay which turns it into a 2way switch.. I want one output going directly to the lights and the...
